DaGenerals Punto GT
DaGenerals Punto GT
Spec:
Seb 4.1 Chip
Garrett T28 Turbo
Front Mounted Intercooler
FSE Fuel Pressure Regulator
Coupe Turbo Wallbro Fuel Pump
330c Fuel Injectors
Custom Exhaust System
Turbo Smart Dual Boost Controller
Smoked Oil Temp Gauge
Digital Boost Gauge
Digital AFR Gauge
Tripe Gauge Pod
Turbo Rocket Switch
Team Dynamic 1.2 Race Alloys
Subaru WRX Bucket Seats
Custom Air Feed
Uprated Plugs/Leads
Lowered 60mm Front 40mm Back
Tinted Windows
Full Respray
Baileys Dump Valve
FXR Custom Elbow
After hitting that pothole i took car to garage to assess the damage, engine mount, drive shaft took the brunt of it, also took the front driver break pipe out, im beginning to think the engine mount was worn aready as a pothole shouldnt have caused it
I have ordered the engine mount and drive shaft and they have arrived today the down pipe has arrived and is getting done on sat (ill take some pics) also on satuday is the dual boost controller. I had also got a front mounted intercooler which we fitted last night, we incurred some problems with not have the fitting bracket and having to move the radiator over an inch or 2 so we could fit the boost pipes.
With the FMIC fitted i decided to give it a wash and take a pic :)
Thought i should update this a bit since im falling behind on it... here goes............
As you all know i changed from the Graphite alloys to white team dynamics
Also made a start on changing the leather interior and putting some comfy subaru seats in, while we were there we changed the downpipe.
Just bought a new K&N to replace the ram air:
What im looking to do next:
Replace all vac pipes with red ones.
Oil catch tank.
Remap from FC Performance
Big MAF Conversion
Forged Pistons and Conrods
Piper 280 Camshaft
Fidanza Flywheel
Coilovers?
looking like your getting it to the way you want it now :D
hows it feeling with the new kit in it
Was a bit of a pain for a while getting the fueling right but that seems to be under control now, just need to get the cam installed and get the remap done to smoothing things out.
It certainly shifts though.
muppet42 said:
Looks like a great car, some really nicely chosen mods too :smile:
With the headlights, I reckon the matt black could be a goer. These are the basically the black versions of the ones you have...
See that looks a lot better
