Ah, my bad. I thought from the way you were all talking about getting in someone who knew about timing yesterday that was the problem rather than needing confirmation
Martyn said:Oh yes - we were going to check throttle body and refit with the one from FiaSco, but it was getting cold and none of us could really be bothered fettling away.
Martyn said:@marti155 and @Johnno933 had already rebuilt the exhaust and pasted up the water pump. Obviously that needs 24 hours to set properly, so we'll use the opportunity to clean out the header tank - systems already been flushed out!
We've also been gifted a nice new temperature guage which we'll wire in at some pont soon - non essential for MOT, but when we have a mo we'll get it fitted for all the time it'll take.
So - exhaust repaired, throttle body swapped (cheers Stu!) the 4th spark plug changed and it was dark in the 'deen....time to jump yellow and see if all that hard work had paid off. Not only did she turn - and I'll be quick to point out, this wasn't even a 30 second run - but she's sounding a LOT better. And Stu was one of the first to point that out.
Ever the optmist, I'm quietly confident that somewhere in todays work we've possibly resolved the dodgy running issue.
Tomorrow - swap the front breaks over from FiaSco to yellow, plumb in the header and refill teh water, engine flush (still need to get a new copper washer and sump key but that won't be an ask) and with a little luck we can think about the MOT again!!
Nackered? Definately. Satisfied? Hell yes.
Massive thanks to everyone for todays shift!
