Panda
Panda
John Bunker
My Panda, 2005, 1242 cc petrol, had a new cambelt fitted at 180,000 kms then engine wash, a few kms developed a missfire and then stopped. Engine will fire but not run. Diagnostics show zero faults, fuel at correct pressure. If fuel is poured into inlet manifold the engine will run, so problem is with injector control. Auto mechanic and auto electrician have given up after several days. Engine now totally dry.....any help please? John
Hi. :)
The 2004/10 panda should be pretty straightforward.
Have they substituted any parts?
So : tank pump is supplying correct pressure to rail
Timing and spark appear ok as tipping in metered fuel makes it fire...
Does it actually RUN or just pop and phutt?
Charlie
