Wouldn't bother with the remap tbh, firstly i don't think many, if anywhere will touch that ecu, secondly the gains from it would be miniscule.
p60 bottom end, p75 cam (don't forget the shims), decent exhaust, decent cold air fed induction will make a decent difference.
Not sure what can be done with throttle body on that setup. (one of the best things about earlier spi setups is the better availability of tuning goodies, bigger tb's, better inducton setups etc) If you're feeling adventurous and possibly not against a little rewiring or ecu swapping, i believe it's very possible to do a p75 swap from the mpi setup relatively easily.
