Old 07-05-2021   #1
''LUIGI''
2668GRIFFIN's Avatar
2668GRIFFIN has donated!
gear knob removal
Hi All
What's the method to remove the gear knob?
And is the gaiter fixed to a frame?
I'm having a new gaiter made in black leather with green white red stripes topped off with a black aluminium gear knob with red embossed 12345R
pics to follow
luigi
Likes Qube O liked this post
2668GRIFFIN is offline Reply With Quote Quote
Old 07-05-2021   #2
''LUIGI''
Re: gear knob removal
Here are the pics
The gaiter in the picture is for a 500 but mine is being made for the fiorino
ID:	217527   Click image for larger version
Likes Red Van Man, Qube O liked this post
Old 08-05-2021   #3
it`s very simple, you need pull up on gaiter ( firm but gently ) and when gaiter become free you need turn knob counterclockwise ( it is on thread like nut )
On the bottom of your OEM gaiter will be some sort of plastic frame, you need to remove that, attach to new gaiter and re install everything back, in theory all is simple, however...
1) Depends on quality of new gaiter, you may have pre cutted holes to instal plastic frame, but on mine it was cutted in wrong place so you may need sharp blade to correct that
2) Leather is thicker than OEM plastic crap, so it may not fit correctly but don`t worry about it, leather is flexible and compressible, after couple weeks everything should settle
3) New knob my have no thread or thread with different size, you may need some adaptors
Likes 2668GRIFFIN, Qube O liked this post
Mr Happy is offline Reply With Quote Quote
Old 08-05-2021   #4
this black cup is an adapter you may need
Likes 2668GRIFFIN, Qube O, varesecrazy liked this post
Old 09-05-2021   #5
''LUIGI''
Hi
My new gear knob does come with an adaptor kit and the knob is secured by an allen screw to lock into place
The gaiter is oem pattern and should fit exactly
The knob even has the grove around the bottom to secure the top of the gaiter
Luigi
Likes Qube O, Mr Happy liked this post
Old 10-05-2021   #6
''LUIGI''
Hi All
Here is the link for lovely new gear stick Gaiters
If you want the one i have you have to message the seller as they are made to order
You can have the green white red strips on drivers side or passengers side of the gaiter
Luigi
https://www.ebay.co.uk/str/thetuningshop?_bkw=fiorino
Old 10-05-2021   #7
''LUIGI''
Great customer service
Highly recommended
Luigi
Name:	Screenshot 2021-05-10 142625.png
Old 14-05-2021   #8
''LUIGI''
Hi All
New gaiter and gear knob fitted
Took about an hour to do but what a transformation it has made
Well happy with the outcome
The gaiter I had made fitted a treat it even had the fixing tab slots pre cut!
Luigi
Old 14-05-2021   #9
''LUIGI''
Gaiter picsClick image for larger version
ID:	217701Click image for larger version
ID:	217702Click image for larger version
Likes Mr Happy, Qube O liked this post
(T) gear knob removal rogerowen Cinquecento / Seicento 10 31-05-2016 12:04
(G) Gear knob removal Brad Cogan Grande Punto 2 01-12-2015 21:27
(S) Gear knob removal Beesley23 Grande Punto 12 04-09-2010 19:28
(T) gear knob removal help bravo project Bravo / Brava 9 07-09-2009 17:02
