FIAT Auto Specialist Team
Old 23-01-2021   #1
Please Please Help, Fiorino - EML and Poor running
Afternoon Everyone,
I have a 2011 Fiorino, Its lacking power in the low gears and the EML is on and when this happens the engine goes into limp mode....
Im in desperate need of help ?????
This has been in the garage with the correct diagnostic equipment, its had a full service, injectors, glow plugs, new airflow sensor, the egr has been out and cleaned and it STILL has the same issue. When is plugged in on the dyno and running everything fires at the correct time I am told.
Im all out of money and options.... anybody have any ideas?
symptoms are- poor running at low revs and then it will put the car into limp mode
I reply on the car for work and have no other option for transport..... i'm really stuck here and am down to my last pennies
Likes Qube O liked this post
itstimmate is offline Reply With Quote Quote
Old 23-01-2021   #2
Re: Please Please Help, Fiorino - EML and Poor running
What is the code or codes that causes the eml light to come on?
Surely the garage read the fault codes before replacing all the parts replaced?
Must have cost a fortune.
Likes Qube O, varesecrazy liked this post
jackwhoo is offline Reply With Quote Quote
Old 23-01-2021   #3
Your post reads like the garage returns the vehicle to you with the eml light still on and the fault still present, is that correct?
Old 23-01-2021   #4
varesecrazy has donated!
Hi
1248mj ?
What year??
Sounds like pre.DPF
All these garage charges:
What faults WERE logged
What have they changed?
What faults are NOW logged
You say its low power in low gears.. does it fly in 5th .. or cannot get there?
More info please
Old 23-01-2021   #5
they still have the car, and the diagnostic equipment was throwing up codes for the above also, he then cleared the codes and took it for a drive and the same thing happens again, limp mode and poor running
Old 23-01-2021   #6
Quote Originally Posted by itstimmate View Post
I dont see reference to a Specific Error
ARE YOU SURE its not DPF related ?
Old 23-01-2021   #7
Its a 2011, I believe the fault codes were for injectors, glow plugs and maf sensor, all of which have been changed.
The car runs well when its in high gears and at high revs and doesnt go into limp mode, this only happens in low revs in gears 1-3
Old 23-01-2021   #8
Ok basics
Have you had years of trouble free service from it. or a recent purchase ?
Any hints of issues before this..
Previous work carried out.. clutch change.. ? as an example
Old 23-01-2021   #9
Ive spent a lot of money, and have basically lost faith.... really stuck
Old 23-01-2021   #10
It was a recent purchase, it ran well for a week and then this happened. There was no service history with the car so I don't have an idea of previous work done. It was a mistake on my part to buy a car so blindly, however, when I test drove it there were no signs of this problem.
Old 23-01-2021   #11
Its had fuel filter, air filter, new oil, oil filter, glow plugs, 4 new injectors (fml), maf sensor & egr cleaned out
Old 23-01-2021   #12
please let me know if there's any more specific information I can get from the mechanic that might help, appreciate any and all help
Old 23-01-2021   #13
DO make sure they have reset all of the DPF ond Oil settings in the ECU
LOTS of garages mess this up..
Get the actual fault CODES from them.. again this could tell a tale..
You might just have a random electrical problem..
But go through the common issues 1st
Old 23-01-2021   #14
Plenty of people use diagnostic kit that doesnt work well with the Marelli and Bosch kit on the diesels.. or the mix of kit on many modern Italian cars
So you might get misleading CODE descriptions.. thats why knowing the actual CODE is very helpful
Similarly..
If they dont have the knowledge or kit to reset certain service parameters the diesel engine can be damaged..
What kind of garage are you using?
Any specific brand loyalty..??
Old 24-01-2021   #15
Thanks for the help I will get back to you guys with some codes tomorrow and ill make sure they reset oil & dpf
thanks
Tim
(T) EML flashing and rough running ,no codes dadandlad Cinquecento / Seicento 7 02-04-2016 21:15
(T) Engine running rough, EML on and off, loss of power etc. Scoobysnacks Punto (Mk2/2b) 10 26-03-2014 15:55
(T) poor running marcevs72 Cinquecento / Seicento 13 01-07-2012 13:46
(T) Poor 1.2 Running. Rigby Bravo / Brava 4 04-11-2010 20:26
(T) Poor running mickn Bravo / Brava 9 11-03-2006 22:49
