![]() | #1 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Battery drain 2019 florino Found the circuit.. 5amp.. fuse 37 I think.. but that's as far as it goes.. Clock flashing and airbag light on..
![]() | #2 | ||
Posts: 26,490 Thanks: 1019 Trader Rating: 0 ![]() | Re: Battery drain 2019 florino Hi ![]() There have been several who found the Blue and Me box under the seat that causes a drain.. ![]()
![]() | #3 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Battery drain 2019 florino Thanks for the reply. I'm not sure this has blue and me (bluetooth) This van doesn't even have electric windows, surprised it came with a steering to be honest I'll run out and have a quick check.. Edit: no box under the seat.. it started fine again just there but as I turn ignition on I get a short burst of clicking from under the bonnet. Also clock always resets and airbag light on
![]() | #4 | ||
Posts: 26,490 Thanks: 1019 Trader Rating: 0 ![]() | Re: Battery drain 2019 florino Check battery condition.. Then run a jumplead from battery negative to engine bodywork Failing earth bond between engine end chassis to battery does happen Clock resetting is a voltage drop thing.. the airbag warning could be similar Sounds like there isnt much else to flag errors ![]()
![]() | #5 | ||
Posts: 26,490 Thanks: 1019 Trader Rating: 0 ![]() | Re: Battery drain 2019 florino Is it actually 2019..? There must be some warranty..??
![]() | #6 | ||
![]() | #7 | ||
Posts: 5 Thanks: 0 Trader Rating: 0 ![]() | Re: Battery drain 2019 florino Rang up garage, its booked in for tomorrow under warranty... The person on the phone seemed to know what the issue was by me giving then a quick distribution. Hopefully will be all sorted..
![]() | DanHem | Punto (Mk2/2b) | 4 | 27-02-2012 20:57 |
![]() | Richpea | Barchetta | 4 | 26-04-2009 15:42 |
![]() | raymied | Punto (Mk2/2b) | 15 | 21-04-2009 19:38 |
![]() | logga | Punto (Mk2/2b) | 2 | 05-05-2008 23:02 |
![]() | barneyb | Punto (Mk2/2b) | 6 | 22-08-2005 19:09 |
