Can Someone confirm the correct size and rating
The one currently fitted is I believe to be wrong as the the strap that holds the battery down is slack so the battery is not tall enough
LUIGI
Fiat part number 71751133
Strangely on the multipla the strap appears to be there to stop anyone losing the battery hold down clamp which is attached to the end of the strap-fine idea fiat(-:
Hi
To be fare the 2x1 was me being sarcastic
As wood to mentioned to solve the loose strap issue.
Lol
Hi
But when I checked on many parts sites it says the 027 does not fit
Will the alternator be OK with higher than 50 Ah?
I'm pretty sure that 50Ah is the maximum I can go, but the size you mentioned is the correct dimensions that I need, but all the parts places I've been on say this is not the correct one
Luigi
