Mr Brown 2021
- Dec 10, 2020
- 5
- 2
Hello All, common question, apologies... I have the van version, first symptom, only blower working on 4, that has failed now too. I removed and cleaned the motor and jumped battery tested and worked fine. Removed resistor and tested, faulty. Father had a spare resistor from a Corsa which multimeter tested looks ok (i assume its the aircon version and looks the same as the removed one). There was no signs of melted wires anywhere. I have connected the Corsa resistor and the motor and turned the matrix controls and nothing. Tested the wires and appears to be no power. There is power coming to the control panel (it lights up) but I know there are the equivalent 5 prong connector on the back for the motor.
Is there a relay for the heater control power in the loop with the 5pin connector coming in the back (checked fuses ok) or is it something else?
There is NO info on the Relay numbers in the engine bay
I assume the next step would be to test if power is coming in the back of the control power (looks a big job tho because of the heater control cables)
TIA
TIA
