HI FOLKS
As I'm fitting a cone filter and ditching the current Air box engine cover will this maff work?
The one pictured on the left is the one currently fitted to oem setup with the two lugs that bolt to air box but the one on the right is what I'm after, this one is fitted to a Vauxhall CDTI engine and would solve the issue.
Is there any reason why this will not work as i don't want the lugs on my new set up
The connector is identical as well as the engine capacity and output hp
Luigi
Luigi
