Hello guys, this is my first post on this Forum, so warm welcome to everyone.
I have Peugeot Bipper ( almost Fiat ) 1.3 Multijet with DPF 45k miles Manual, 67 plate
The problem is that when engine is cold ( first drive in the morning ) on 4th gear ONLY between 1500 and 2000 RPM and with steady throttle my van is juddering and driving like kangaroo. After 30 minutes of driving all is going back to normal. If I press the throttle or reduce power or change gear everything is going to normal too, so the problem exist ONLY on steady throttle. A few days ago I also noticed that van start juddering on 3rd gear during acceleration when cold at passing 2000 RPM. :bang:
When hot, all is smooth and perfect
Any ideas ? I suspect injectors but you have more experience with this engines so maybe it is something else.....
btw no fault codes or light present
many many thanks,
cheeers !
many many thanks,
cheeers !
