im Axle Specialists
Old 3 Weeks Ago   #1
Clutch slave cylinder bleeding
Hi all , gear shifting is getting very stiff , I was told to bleed the clutch slave cylinder but the bleeding nipple seems to be moulded on to the slave cylinder and there is no hex head to undo it , nothing on google on how to on a fiorino ,any help will be appreciated , thanks
Likes Qube O liked this post
Gizzybusy is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Turkey
Re: Clutch slave cylinder bleeding
There is a clip that locks the hydraulic pipe into the cylinder. You need to pull that clip up and pull the pipe out just a little bit(don't take it out) and that should bleed out.
Likes Gizzybusy, Qube O liked this post
Besa is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
varesecrazy has donated!
Quote Originally Posted by Besa View Post
I was wondering if that was possible..
Clutches are weird.. I had one 20 years ago that was bone dry..!!
The independent supply was choked with crud.. took 60psi to shift it
Perfect after
Looks like you will need an assistant to bleed this well
Slacking off and controlling the pressure : flow could be tricky..
Good luck
Do let us know how it goes
Likes Gizzybusy, Qube O, Besa liked this post
Old 3 Weeks Ago   #4
chris3234 has donated!
Does it have a flat section on top that can be turned in know the slave on my Tipo and previous 500 where like that
chris3234 is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
This section
Old 3 Weeks Ago   #6
Thanks , that's exactly what I did , once the hose is pulled out about 2 mm , the oil starts running out of the bleeding nepple .
After watching a few vids on how to , I came up with a better way of bleeding it .
Filling the reservoir to the top.
A flexy hose on the bleeding nepple into a bottle
Then pressurising the reservoir , which should push oil down all the way out to the bottle through the nepple. I'll give it a go sometimes this week.
Likes varesecrazy, Qube O, Besa liked this post
Old 3 Weeks Ago   #7
Well , I bled the clutch slave cylinder , still hard getting into reverse gear ( crunching ):and a little stiffer when changing gears while driving .
Changing gears while engine is off is good, this only happens when engine is running.
No sign of oil leaks on slave cylinder , mystery!!!!!
Old 3 Weeks Ago   #8
Qube O has donated!
Suspect Clutch ???
Likes Gizzybusy liked this post
Qube O is offline Reply With Quote Quote
Old 3 Weeks Ago   #9
See topic "reverse gear crunching" particularly posts 10 and 11 which with similar symptoms to yours, put it down to clutch release springs/fingers and remedied it with a new clutch.
My crunching disappeared over the winter but has just started to reappear with commuting in the hot weather. I'm going to have to bite the bullet and get a new clutch sooner or later.
Quote Originally Posted by Gizzybusy View Post
Likes Qube O, Gizzybusy, varesecrazy liked this post
Porretta is offline Reply With Quote Quote
Old 3 Weeks Ago   #10
''LUIGI''
2668GRIFFIN's Avatar
2668GRIFFIN has donated!
Hi
Had the same symptoms on my van and it was a weak clutch pressure plate
Luigi
Likes Qube O, Gizzybusy liked this post
2668GRIFFIN is offline Reply With Quote Quote
Old 3 Weeks Ago   #11
Quote Originally Posted by 2668GRIFFIN View Post
Hi
Luigi
Did you have to replace it ??
Old 3 Weeks Ago   #12
''LUIGI''
Yes
Could hardly get reverse and 1st gear
Changed the slave cylinder as well while it was apart
Luigi
(G) bleeding new clutch slave cylinder Brian1 Multipla 3 29-10-2014 10:10
(T) 1.4 Tjet Clutch with Slave Cylinder or Concentric Slave Cylinder? Eridanny Bravo 9 22-12-2013 22:25
(T) slave cylinder bleeding josize Punto (Mk2/2b) 18 15-11-2011 00:09
Clutch Slave Cylinder, bleeding? joem FIAT Boo Archives 1 09-09-2003 15:55
