![]() | #1 |
Posts: 66 Thanks: 0 Trader Rating: 0 ![]() | Anti roll bar bushes I’ve got a slight knocking/clunking noise on the drivers side when going over bumps/potholes. I’ve changed the drop links but the noise is still there. My next thought was the bushes, but can’t find any information or tutorials about changing them. Are they easy to do or is this one of those awkward jobs that requires the subframe to be dropped?
__________________ Fiat Fiorino SX Multijet van, Ford KA & Vauxhall Astra H owner. |
![]() | #2 | ||
Posts: 963 Thanks: 75 Trader Rating: 0 ![]() | Re: Anti roll bar bushes Top Suspension Bearings ??
![]() | #3 |
Posts: 66 Thanks: 0 Trader Rating: 0 ![]() | Re: Anti roll bar bushes
![]() | #4 |
![]() | Re: Anti roll bar bushes Sounds like a broken spring. I had the clunks on roundabouts if the road surface was rough (and Sheffield was before re-surfacing and is now getting that way again a year later ![]() Then the B&Me died... R-V-M
__________________ 2017 Qubo Hillbilly Azure 1.3 MJ 80PS Dualogic |
![]() | #5 |
Posts: 66 Thanks: 0 Trader Rating: 0 ![]() | Re: Anti roll bar bushes Sounds like a broken spring. I had the clunks on roundabouts if the road surface was rough (and Sheffield was before re-surfacing and is now getting that way again a year later ![]() Then the B&Me died... R-V-M
![]() | #6 |
Posts: 66 Thanks: 0 Trader Rating: 0 ![]() | Re: Anti roll bar bushes I’ve had another look at my van today after doing an oil change. There is definitely an issue with the strut bearing on the drivers side, I held the spring whilst turning the wheel and I can feel the spring “twanging” as the wheel is turned. I’ve not had a chance to check the passenger side yet as I didn’t have anyone to turn the steering wheel for me.
![]() | #7 | ||
Posts: 963 Thanks: 75 Trader Rating: 0 ![]() | Re: Anti roll bar bushes Have them both changed, no point doing one, sods law says the one left untouched will fail next week. Look on here for the little trick most of us do to protect these bearings.......Cheers Qube O.
![]() | #8 | ||
Posts: 2,155 Thanks: 114 Trader Rating: 0 ![]() | Re: Anti roll bar bushes Did not know there was a trick???? I bought febi Bilstein one for mine and still ok They are completely encased in rubber Luigi
![]() | #9 | ||
Posts: 963 Thanks: 75 Trader Rating: 0 ![]() | Re: Anti roll bar bushes ![]() ![]() ![]() ![]()
![]() | #10 | ||
Posts: 2,155 Thanks: 114 Trader Rating: 0 ![]() | Re: Anti roll bar bushes I still think its water being fired up from the wheel onto the bearing and hot from the top! LUIGI
![]() | #11 | ||
Posts: 963 Thanks: 75 Trader Rating: 0 ![]() | Re: Anti roll bar bushes Could be......but if you look the rain water from the top drips merrily on to the whole top bearing area, I can pop the bonnet the day after being out in the rain, and find a nice little pool of water sitting there, poor design by Fiat, hence they replaced a lot of these under warranty years ago, including mine........Cheers Qube O.
![]() | #12 |
Posts: 66 Thanks: 0 Trader Rating: 0 ![]() | Re: Anti roll bar bushes Just had word from the garage and everyone is correct in saying it’s the strut top bearings. Garage have said what we all know that they are quite common on this vehicle and they say it’s not a safety issue (they are MOT testers) so could be left if I wanted tooas there’s every possibility the noise would be back in six months. However I’ve opted to have new struts and bearings as the van has 122k miles on it so the struts are probably due for replacement anyway.
![]() | sismithin | Bravo | 3 | 14-09-2018 16:29 |
![]() | Voko | Barchetta | 4 | 27-08-2018 19:35 |
![]() | dtwelve | Bravo | 2 | 28-10-2017 23:07 |
![]() | AdeMahoney | Idea | 2 | 06-09-2016 14:04 |
![]() | rholtby | Punto (Mk2/2b) | 2 | 18-10-2010 23:41 |
