General Wiper Arm Spray Jets
WISBECH,CAMBS
Just bought the necessary parts to convert the screen water spray jets to wiper arms
The spray jets on the Fiorino is a bid inferior and always find the passenger side of the screen never is clean after a spray and wipe, so I have bought some spray jets that clamp around the wiper arms so that the water can be more directed where it need to be
I will post up pictures when done
LUIGI
Yes, the manual states (proudly?) that the jets are not adjustable or are pre-set suggesting that they are already perfect! Not so ?
Did you find an off the shelf kit or are you manufacturing from made up parts?
I keep trying to think of ways to improve the rear wiper which on every Qubo I've had has been rubbish, always missing the top end of the sweep. First Qubo I made an attempt to bend the tip which resulted in having to buy a new arm and that proved the point that as a made-for-the-job, it doesn't work as the new one was as rubbish as the snapped one (before I snapped it! - and after..) Without looking at the modus operandi of the supports for the blade I've thought as I watch it fail to clean the top arc, that it requires some packing to make the blade go nearer the screen but I need to look and see how it could be done.
Has any owner here cured the inadequacy?
R-V-M
LUIGI
These are the ingredients I have bought to do the job [There are Two jets]
also I have got some tiny cable ties to hold the tubing underneath the arm so it cant be seen[so much]
Peugeot used this method on some of there cars in the early 90's although it was I spray bar that clipped on the wiper arm
LUIGI
