Well here is the badge
I have since modified it to fit the van bonnet by removing the 500 fixings as its impossible to use them as the bonnet is double skinned and there is no way to bolt from inside the bonnet
The solution is to remove the chrome strips fix the badge from the outside and then refit the strips hiding the screws
The Fiat badge in the centre I can get to from inside the bonnet as there is a large hole behind the original so have kept that fixing on the badge
LUIGI
