Hi all
Fiat fiorino Van 1.3 Multijet Diesel mnfctr 2008 registered 2009 67000 miles on the clock.
There is no DPF on this Van.
On checking oil, level is rising considerably.(Fuel In Oil)
Have ordered Back Leak Off Tester (testing Fuel Injectors)
Whilst hooking up to Scanner the following errors displayed on Multiecuscan.
P0110-15- Air Temprature sensor(air flow meter) open Circuit/short circuit at +V batt Light ON
P0100-15- Air Flow Meter Open Circuit/short circuit at +V batt Light ON I
P0504 Brake Signal
P2264 water in fuel filter sensor
Check engine light is ON
If i clear errors they just return.
Are any of these errors associated with the rise in oil level?
Is the open circuit/short circuit to do with the MAF or the wiring to it.?
So far have cleaned MAF Sensor (may renew). Seems to have made no difference.
In spite of all the above vehicle starts ok,runs ok and pulls ok.
Any advice Please.
BTIA gromit
P0504 Brake Signal
Any advice Please.
BTIA gromit
