Thread Tools
Old 13-08-2019   #1
''LUIGI''
2668GRIFFIN's Avatar
2668GRIFFIN has donated!
Dash clocks
Are dash clocks programmed to the ecu?
I believe the punto clocks are the same and fancy the white dial version
LUIGI
Likes Qube O liked this post
2668GRIFFIN is offline Reply With Quote Quote
Old 15-08-2019   #2
''LUIGI''
Re: Dash clocks
Anyone with dash clock swap abilities for these
Old 19-08-2019   #3
''LUIGI''
Re: Dash clocks
Anyone?
Old 26-08-2019   #4
Israel
Re: Dash clocks
What do you mean programmed to ecu? All the data has to go through ecu at some point, since dtc freeze frames contain speed, acceleration and somesuch. I never disassembled the gauge cluster, but I would guess it is as simple as disconnecting a cable harness. This cable harness probably would go into the ecu. Which means the clocks are a passive device by themselves.
e1team is offline Reply With Quote Quote
Old 26-08-2019   #5
Israel
Re: Dash clocks
https://www.reddit.com/r/cars/commen...tent=post_body
I found this. May be helpful.
TLR if the gauges from same mfg then there should be no problem.
Thanks 2668GRIFFIN thanked for this post
Old 26-08-2019   #6
''LUIGI''
Re: Dash clocks
The fiorino is based on the Punto Grande so should be the same i'm guessing
Luigi
Old 28-08-2019   #7
Re: Dash clocks
I know on some Vauxhall’s the clocks have to be (for want of better terminology) “divorced” & “married” from/to the ECU using Tech 2 or Op-Com. I don’t know if it’s the same with Fiats
Our Doblo camper has a non functioning engine management and glow plug lights, I’d be interested to know if you can just swap the clusters as I’d rather these warning lights were working.
Fiat Fiorino SX Multijet van, Ford KA & Fiat Doblo Cargo camper van owner.
stuartinlancashire is offline Reply With Quote Quote
Thread Tools
(T) dash clocks nikkiy9 Stilo 5 01-03-2012 08:22
(S) dash clocks nikkiy9 Punto (Mk2/2b) 1 07-09-2009 08:11
(T) dash clocks danny120T Bravo 4 30-03-2009 23:48
(T) Cinquecento Dash clocks iansoutham Cinquecento / Seicento 3 02-05-2008 06:53
(S) New Dash Clocks lacey_punto Punto (Mk2/2b) 21 09-12-2006 22:15
