When engine is hot reverse lights fail to work could this be a fault with the switch
Luigi
Luigi
Switch looks easy to do just needing a 19mm ring spanner but on looking at its position its between the fill and drain plugs so obviously I will lose gearbox oil and I will need to get some when I'm next out.
Does anyone know how much oil these take and what viscosity?
LUIGI
You just wind the old one out till it’s just about ready to drop, have the new one ready and unscrew the last bit of thread on the old one and quickly whip the new one into place and screw it in the first few turns or as much as you can by hand.
At worst you lose a few drops.
If you fancy it you could tackle a gear box oil change while you’re considering topping it up. If you can top it up you can drain it.
