Thread Tools
Old 3 Weeks Ago   #1
Oil leak and ID
Hi folks
Hope your all having a good un....
2008/9 fiat fiorino 6 door van
1.3 multijet diesel engine
appears to be a small leaki of oil from behind the bottom pulley on the engine
Whilst the leak is quite small
I hope a technical mind can help me out here
1
Pls confirm if the crankshaft oil seal is on the bottom pulley wheel of the engine.
2
Will i be able to change the crankshaft oilseal without removing the engine.
3
will i have to re[lace timing chain cover gasket whist carrying out this Job
4
would it be possible for someone to tell me what each of the pulley wheels on the rubber belt do.
For id sake i number pulleys on rubber belt with 1 at the top etc.
Many thanks in advance gromit
Likes Qube O liked this post
gr0mit is offline Reply With Quote Quote
Thread Tools
(T) 1.4 8V Oil Leak from Head Gasket / Oil Seal? Terenc3Le3 Grande Punto 3 06-09-2016 15:36
(T) Seicento Oil leak & seperate Water Leak from Head?!?! Please help. Hamilton Cinquecento / Seicento 22 21-10-2010 12:45
(T) Oil leak fixed, but still leaks oil... punto2009 Punto (Mk2/2b) 5 19-08-2009 18:39
oil leak, no oil leak, that is the question? new to hgt FIAT Boo Archives 5 07-03-2006 19:30
(T) Oil leak, tappets, now engine whine and oil burn Extintor Punto (Mk2/2b) 5 15-11-2005 11:15
