Hi folks
Hope your all having a good un....
2008/9 fiat fiorino 6 door van
1.3 multijet diesel engine
appears to be a small leaki of oil from behind the bottom pulley on the engine
Whilst the leak is quite small
I hope a technical mind can help me out here
1
Pls confirm if the crankshaft oil seal is on the bottom pulley wheel of the engine.
2
Will i be able to change the crankshaft oilseal without removing the engine.
3
will i have to re[lace timing chain cover gasket whist carrying out this Job
4
would it be possible for someone to tell me what each of the pulley wheels on the rubber belt do.
For id sake i number pulleys on rubber belt with 1 at the top etc.
Many thanks in advance gromit
1
2
3
4
