stuartinlancashire
I’ve just done an oil & filter change on my Fiorino, however I’m now struggling to reset the service counter & DPF counter with Multiecuscan and hope someone can help.
I select my Model/Version as “Fiorino ‘07 1.3 Multijet” (the only other option for the Fiorino is 1.4 8V)
Then I select “Service” & “Service Interval Reset” and press connect.
The screen says “connect adapter 3/yellow” I press Y
Screen then says “Connection Failed ELM327 -> ECU Connection failed
CAN bus error. Check if interface is properly connected to vehicle and correct vehicle/module selected”
I’m using an ELM 327 Interface v1.4 which is supposed to be Canbus compatible and work with Fiat vehicles so I’m a bit baffled about why it won’t work. I tried using the Qubo 1.3 multijet option but had the same result. Any help or advise would be appreciated. Thanks.
