Old 14-02-2018   #1
Fiorino 1.3 trouble starting
1.3D multijet, 10 plate
Turns over for ages in the morning before starting....maybe fifteen minutes!!!
Starts generally ok after that.
Big of 'lag' when you press accelerator - pretty much all the time.
Glow plugs - ok
In tank Fuel pump - pumps out when disconnected from filter
Filter - clear
Tested the readings on MAF sensor, the Fuel Rail Pressure Sensor and the fuel rail pressure control valve.
Fuel rail pressure control valve - all within the spec [as per RAC video on youtube]
MAF sensor as follows
Ignition On only - Green and Yellow reading 21mv [RAC video says should be 3-4mv]. Others oK
Engine idling - Green and Yellow now reads 12.1mv [cf 10mv from RAC video] others ok
Fuel Rail Pressure Sensor readings
Ignition on only - all readings fine [0.2mv, .5v, and 5v]
Engine on and Idle - Blue and Purple reads 2.4mv [cf 9.4mv as per RAC], others are fine.
Thoughts please.....I'm leaning towards the high pressure fuel pump being duff...but don't want to shell out £300 to replace it if it's not wrong....
Can I hire a high pressure test kit from anywhwre national??
Likes Qube O liked this post
aspar is offline Reply With Quote Quote
Old 14-02-2018   #2
Re: Fiorino 1.3 trouble starting
meant to say...no sign of fuel leaking at the hp fuel pump.
We had though of changing the seals but no leak seems to negate that??
Old 15-02-2018   #3
just an update...
yesterday it started being difficult to start even when hot [eg ten mins after turning off it struggled to start]
Then this morning it's not starting at all.....
Old 15-02-2018   #4
chris3234 has donated!
Does it start it better if you turn ignition on let pump prime turn off and repeat a few times to build up maximum pressure?
chris3234 is offline Reply With Quote Quote
Old 16-02-2018   #5
Not tried that. Will try tonight when I get home.
Old 18-02-2018   #6
I had to have the main high pressure diesel pump replaced with genuine fiat one, ( tried 2 X reconditioned ) the only problem was cost as it was, and still is £1000+ just for the pump. Also 2 X injectors, this cured it, starts on the button, almost before I release the key.
Mad one is offline Reply With Quote Quote
Old 18-02-2018   #7
Quote Originally Posted by Mad one View Post
That does sound like a little bit of parts darts was played there
K333fer is offline Reply With Quote Quote
Old 19-02-2018   #8
Not too bad, the injectors were defiantly knackered, this cured some hesitation, however it became pretty obvious that the pump was not doing its job, problem then being, that the 2 reconditioned ones from 2 separate motor factors kept throwing up fault codes ( I was there on both occasions)
After changing for a brand new fiat supplied pump ( hence the cost ) it started first time, every time as it should.
Used garage for years, trust the guys there as they welcome any questions I have and always keep me updated as to what I need and check before going ahead with any further work.
Old 19-02-2018   #9
That was probably due to the incorrect pressure controller fitted to them , I have a leak on mine at the moment we looked it up at my local factors as my mate is the manager there ,
Even cross referencing from the genuine part no across to Bosch brings up a different part no to the one thatís fitted to mine
Old 19-02-2018   #10
Quote Originally Posted by K333fer View Post
So is the best thing to swop over the pressure controller from the old pump to be sure???
Or buy a pump with the controller already fitted.....
Old 19-02-2018   #11
Problem is that if you cannot match the fiat number to a Bosch part you are in the same boat as I was.
Having to buy a fiat original from fiat is a very expensive route to take, however I had no choice in the matter if I wanted it fixed.
Old 19-02-2018   #12
After much searching and cross referencing I now how a fiat number Aswell as a Bosch no looks like my pump shouldnít be on my car but more likely a Ducato itís been on there since new now
Old 20-02-2018   #13
Care to share them???
Old 21-02-2018   #14
Bloody thing started first time this morning!!!
Old 21-02-2018   #15
Sorry that was yesterday [ie started first thing].....
This morning....spins away merrily without any signs of starting!!!
(T) mk 1 trouble starting bfreer Punto (Mk2/2b) 5 01-03-2011 13:45
(G) Starting trouble fiatStilo1966 Stilo 1 04-04-2010 10:09
(T) Trouble Starting Funkstar De Luxe Barchetta 16 13-02-2009 09:09
starting trouble macca35 Newbie Central 1 16-09-2007 15:38
(T) fiorino 1.7d track rod trouble pinks Fiorino (Mk1 / Mk2) 0 04-05-2007 13:59
