1.3D multijet, 10 plate
Turns over for ages in the morning before starting....maybe fifteen minutes!!!
Starts generally ok after that.
Big of 'lag' when you press accelerator - pretty much all the time.
Glow plugs - ok
In tank Fuel pump - pumps out when disconnected from filter
Filter - clear
Tested the readings on MAF sensor, the Fuel Rail Pressure Sensor and the fuel rail pressure control valve.
Fuel rail pressure control valve - all within the spec [as per RAC video on youtube]
MAF sensor as follows
Ignition On only - Green and Yellow reading 21mv [RAC video says should be 3-4mv]. Others oK
Engine idling - Green and Yellow now reads 12.1mv [cf 10mv from RAC video] others ok
Fuel Rail Pressure Sensor readings
Ignition on only - all readings fine [0.2mv, .5v, and 5v]
Engine on and Idle - Blue and Purple reads 2.4mv [cf 9.4mv as per RAC], others are fine.
Thoughts please.....I'm leaning towards the high pressure fuel pump being duff...but don't want to shell out £300 to replace it if it's not wrong....
Can I hire a high pressure test kit from anywhwre national??
Glow plugs - ok
Filter - clear
