Fintious maximus
- Aug 31, 2017
- 30
- 13
Light has come on and my obd2 scanner wont link in with the van. Do I need a particular reader? Guessing its a sensor as its driving fine?
Its a diesel and was serviced a couple of months ago so oil should be good. Will check levels anyway. Hate warning lights!!
Just been looking at a Scanex bluetooth obd2 for iphone - anyone know if this will work?
Thanks for that info. Ideally iphone 6 based but have a laptop which is fairly old and slow (not up on computers so no idea what spec). Just want sonething to tell me what the fault is so I can get the right part to replace.
Multiecuscan does not need a fast laptop. Anything running Windows XP or later with a USB port is good enough.
Ebay item
http://www.ebay.co.uk/itm/162678882016 includes all the adaptor leads for functions like power steering and ABS (see compatible vehicles list) or
http://www.ebay.co.uk/itm/271275445368 is enough for the engine on your van.
MES does so much more than any of the other low cost solutions . Most main dealers will charge you more just to read the code and reset the light.
Robert G8RPI.
So have downloaded the software onto laptop and had a quick look. There are 3 variants listed fir the 1.3 diesel engine - how do I know which one mine is?
If you click on "Scan" or press F11 it will scan for and list the modules it finds. Look at the details for the engine ECU and it will tell you which you have.
Robert G8RPI
