N Nigel288 New member Joined Oct 3, 2016 Messages 10 Points 7 Oct 11, 2016 #1 Got the ABS light on and garage gave me this code and says i need a new pump. Is this correct. Attachments 20161011_095736.jpg 1.2 MB · Views: 166 Last edited: Oct 11, 2016
OP OP N Nigel288 New member Joined Oct 3, 2016 Messages 10 Points 7 Oct 11, 2016 #2 Solonoid valve voltage supply c1115 electrical failure. Voltage under minimum level was the message
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,955 Points 7,825 Location Near the M4 Oct 11, 2016 #3 Nigel288 said: Got the ABS light on and garage gave me this code and says i need a new pump. Is this correct. Click to expand... I read that as a comm's fault in the canbus, I'd get the canbus reset (proxyalignment) before spending any money.., that's a very lightweight looking piece of kit..?? not showing ANY codes Charlie - Oxford
OP OP N Nigel288 New member Joined Oct 3, 2016 Messages 10 Points 7 Oct 11, 2016 #4 The code is C1115. It won't let me put pic on.
V varesecrazy Patron member Written 10+ guides Joined Apr 27, 2011 Messages 34,955 Points 7,825 Location Near the M4 Oct 11, 2016 #5 Nigel288 said: The code is C1115. It won't let me put pic on. Click to expand... post it in the TECH section..nobody look this far down the FF homepage.., I'd be tempted to use a FIAT / Alfa specific software.., and see what that reveals.., (multiECUScan.net) Charlie
