Technical 2013 fiorino cabin filter access?
nedro018
Member
how do you get to this filter to change? there's no access from the bottom...does the glove compartment door need to be removed (my guess), if so, then what?
thx
As fare as i'm aware [I've got mine to do] Remove the complete glove box to gain access to the heater assembly, there is panel to remove from the side of the filter housing, and the filter slides out side ways.
Somewhere on here there is a you tube video of it in the fiorino section as i brought this up a few months ago.
LUIGI
thanks both Griffen and Qubo.
mine is left hand drive.
i think Griffen is right, i have to remove the glove door first. i should be able to fugure it out after that.
i looked at a youtube vid for a panda 1.3 MJ and it told me that access was from the bottom and when i got there i found that was not true for the fiorrino/qubo's.
thx all.
