Just a thought
I have a 99CV early Brava (Brasilian spec engine). I had various gauges that were failed when I got the car. I pulled the dash and found that they were all caused due to bad / dry solder joints.
Although my speedo was the one working gauge, there were signs that a previous owner had already remade solder joints behind the speedo.
For me just running an iron around fixed everything. The speedo is electronic pulse driven so I would say that vibrations have lead to electronic failure / bad connections behind the dash panel.
I also had the same thing on all the windows switches. None of the lights worked but a surface mount resistor on the feed to the LED was the cause in each case.
Nice cheap easy fix.
