Brava front door card and trim removal!
M
Michael
Guest
Hiya, I've got hold of a full Fiat brava service manual and have looked at the removal of the door card as my window motors need replacing and it says you require a special tool, is this really required?
the special tool i imagine is the 'allen key bit' Just a philips screwdriver for around the door card and then its an allen key for things like door handle and other bits.
Not sure on removing the motor but i guess its just a normal bolt
Mike
Door card removal requires screwdriver (phillips), allen keys and IIRC hex drive bits.
Nothing specialist at all..
Guides can be found under repair section of the site - with pictures
Members Site ---------My Site
You dont need to remove the door cards to take the door mirrors off do you?? on the bravo its just the plastic cover and 3 allen key bolts that need to be removed.
window motors,.think he's on about the 'side windows' not 'wing mirrors' ;)
Similar threads
D
Replies
Views
6K
David Slaney
D
J
Replies
Views
656
jason
J
G
Replies
2
Views
639
T
D
Replies
Views
535
Dark Lurker
D
I
Replies
2
Views
739
Dark Lurker
D
