nice one mate thanks, but from the sounds of it it may not be that whats at fault.
its really hard to describe, but i'll try and explain my problem.
if im in first or second, in low revs, then put my foot down the car bogs down, and then picks up extremely slowly all the way to red line. But if im just a little bit higher up in the revs (around 2000 - 2500) i can put my foot down and it will put you in your seat and fly through the revs much quicker, and in turn go through the gears much quicker.
ive considered it being down to torque and therefore the clutch, but its not that. I've also considered it being the mixture of fuel/air being why its doing what it does, but im reasonably sure its not that either.
i know of a private strip of road which my friend owns, so ive tried standing starts, and the same problem occurs...
if i start at lower revs and try and set off quickly the car simlpy doesn't shift and even feels like its going through the gears slower. However if i rev it quite high and then set off it picks up much better all the way through the rev range and through the gears.
obviously i know the car will pick up quicker from a standing start if the revs are higher, but seriously, it will not go if i try and accelerate from low revs. it feels like ive jumped out of my 1.8 and into a 1.0 corsa!
ive also noticed that the car is quite touchy when im letting off and putting on the accelerator when going slowly. It seems to jump and then disapears when i accelerate more.
