this is getting confusing keep to the same thread and dont keep starting another on the same subject
anyway if you have the engine running and the bleed valve open what happens??? as water should eventually come out.
it might not come out if engine is not running as water is not being pumped round
other than this as you have changed the thermostat and no difference i would say the heater matrix sounds blocked??
the whole system takes about 6ltrs of fluid so how much have you put in??
