![]() | #1 | ||
Guest | Radio not switching on... had the car fixed...as in head gasket etc. meaning all cables etc were discnnected the radio has no code enabled i went to switch it on., bear in mind no tiem has been set, so its not flashing however it does have the 2 dots to seprate the hours and minutes afgter switching on, the radio light ups but its still the same display with no time but nothing else happens?? any ideaS?
![]() | #2 | ||
Guest | Re: Radio not switching on... does the tape or cd work?
![]() | #3 | ||
Guest | Re: Radio not switching on... havent got a tape to try on but the grundig cd changer is connecter, the chnager itself is operarting however on the radio itself you cannot select the changer etc..there is no operation on the radio checked the fuses..all seem to be ok..i assume the radio fuse wil be titled 'services'? need to buy official fiat fuses as i have half fiat and the other half universal ones.
![]() | #4 | ||
Guest | Re: Radio not switching on... mayube the sunlight deceived me but sorry it doesnt witch on at all driving at the night the light stays on but the display is blank any ideas what is wrong i tried to use the feeder tools but i coudlont pull out the radio...bloody hard to use feeders any other things i can do?
![]() | #5 | ||
Guest | Re: Radio not switching on... By the sound of it, the radio gets current to sustain the memory but the real power feed is not working. Check the fuses left of the steering wheel. ![]() Members Site ---------My Site
![]() | #6 | ||
Guest | Re: Radio not switching on... cheers Sven, ill prob replace them trouble is the orignal fuses the bravo came with are of a very good quality recently any motor factors sell a cheap version. the fuses are numbered and not soldered correctly onto the casing, leaving the blade intact lol i shall also reattempt the feeler gauge tool, as it was struggling to fit yesterday
![]() | #7 | ||
Guest | Re: Radio not switching on... Hi Sven fuses seem in place looking at http://www.fiatboo.co.uk/run-a-bravo.htm#part8 i dont think it may be the same for all bravos but the rest of the areas in he car seem to be functioning well the radio display light coems on, when you press the power button but that its not wording is shown, you can switch off the radio and the display light turns off i took out the stereo and all connectors which had cables were all in, there is a yellow connector which doesnt have wires..but im only using the standard grunding changer not an aftermarlket system so i assume its meant to be an empty connector any more ideas?
![]() | #8 | ||
Guest | Re: Radio not switching on... looks like the door unlock control is in line with the radio so it canot be the fuse as the door unlock works fine.
![]() | #9 | ||
Guest | Re: Radio not switching on... weird magically came on when i was driving has been playign up with screen freezes and some text missing sprayed contact cleaner on most parts, change the 10amp radio fuse and a bit better noticed my aeria is a bitu loose, its a screw in aerial but now it doesnt screw in, it can be pulled off easily is that the issue then>
![]() | #10 | ||
Guest | Re: Radio not switching on... Could be as inĀ*some radios the aerial acts as a ground wire. ![]() "Doctor said to give up Keee-Babs. I said 'No, no-no'" ![]() My Members Page OI! Road safety nutters!! George Orwell ment '1984' to be a warning, NOT a template!
![]() | #11 | ||
Guest | Re: Radio not switching on... cheers OZ however odd behaviour at times on the radio would freeze, meaning no matter how many button pressing does not work.. i can switch it on..and when i switch it off..itll take sometiems 2 minutes to register the OFF button What i can understand these maybe issue with the radio side as in aerial etc BUT my cd changer is external expept attached with a lead cable, why is the CD changer acting the same as the radio>? Does it look liek the stereos gone/ As mentioned i have taken it out and sprayed alot of contact cleaner but to no avail
