R Rumba Guest Mar 23, 2010 #1 Hi, the reverse light on my Brava are not working, i have checked the bulbs and the fuse and both are ok, does anyone have any ideas? regards Rumba
D Darren Guest Mar 23, 2010 #2 My reverse lights packed up and it was the switch. The switch is normally located 'on' the gearbox and will have 2 wires running into a plug screwed into the box. these shoudl be quite cheap if this is the fault Darren
A Anonymous Guest Mar 24, 2010 #3 same here mine was the switch but its not part of the mot so theres no need to rush
