A
Armin
Guest
Hi everyone,
A few days ago the rear right turn signal light (blinker) started behaving strangely.
Symptoms are as follows:
When I turn on the lights, the rear lights work normally, as well as the stop light when I hit the brake. The problem is to be with the blinker.
When I turn on lights and turn right blinker on, it generally does not work, instead, the rear lights and the stop light turned on and off alternately, like a blinker does. When I turn off the lights on switch, blinker work normally (without the lights turned on, the blinker work properly).
Also, when the lights are turned on and I hit the brake while the right blinker is turn on, it do not work. When I release the brake, again, the rear lights and the stop light turned on and off alternately.
Rear left blinker works properly, as light and stop light.
Does anyone had similar problems, or maybe has a solution for this.
Since its difficult to me to explain my problem with words, tomorrow I'll try to upload the video for you.
Thank you.
BR,
Armin
Thank you.
BR,
Armin
