Compression Test - how to do? help what to look for
L
Lemon
Guest
as per title
i need to do a compression test on the car..guessing on the cylinders
just to confirm if my head gasket is gone
ive never doen this before so can you people help me?
many thanks for reading.
Have you got a compression tester? if so, Take out all the spark plugs, and put the tester on each cylinder in turn (this goes in the spark plug hole) Spin the engine 4 or 5 times and note the reading, Do this on all the cylinders. The readings should be more or less the same if gasket is good. Be self evident if gasket blown
Similar threads
P
Replies
15
Views
12K
Dark Lurker
D
D
Replies
3
Views
6K
Steve
S
C
Replies
3
Views
479
Tommy K
T
C
Replies
Views
6K
ChrisKnottIns
C
