C
Cris
Guest
I have the following problem:-
Recently it is very hard for me to change gear. You really have to force the lever in to each gear.
Also, I can no longer engage reverse when the engine is running. If I need to reverse then I have to turn the engine off, select reverse then put my foot on the clutch and start the engine up with reverse already selected.
Incidentally, when the engine is off and the car is stationary each and every gear can be selected with no problems at all.
My UNprofessional diagnosis is that the problem lies with the clutch rather than the gearbox itself, or is this just wishful thinking!
