Handbreak
Handbreak
M
Mighty Bravo
Guest
hi i love driving in the snow and ice and its been snowin so my handbreak hase took a batterin and feels lose the cable feels fine its just the lever that wobbles any ideas on how to tighten it up ???
There are 2 bolts underneath the car (13mm I think) that hold the handbrake assembly in place.
May possibly have to temporarily move heat shield to get to them...
Easy 10min job...
HTH.
i think ill leave it till all the snow has cleared cuz i like gettin wet and cold
could be the mounting has rusted and may need welding up. done a lot like that
Hang on....
You have a fiat, its bloody cold and freezing and you have been able to use your handbrake. What's your secret? Apart from a couple of brief spells, mine has been frozen since Sunday! Learned though, its frozen off now rather than on!
I'm finding the HGT good in this weather, heavy, can pull away in higher gears and the engine braking means not too much use of main brakes (as I have no handbrake).
I didn't know about the hand brake freezing issue so I've always used my handbrake since I bought the car and never had an issue. No idea what the secret is, unless this freezing handbrake doesn't affect 100sx Bravos.
or the 1.2 16v 80sx formula i like puttin formula makes it sounds faster than it is lol
Mine hasn't frozen once in the ten winters I've had the car.
Mark.
Council estate lad.
And proud of it!
A battle of wits with the unarmed is no fun!
Member of the Guild of Experienced Motorists. Lapsed.
..and its been snowin so my handbreak hase took a batterin..
How? Why would the snow effect your handbrake? In 11 years of driving mine have never gone funny when its snowed.
Longest Serving BOO Member
Bravo: Nov 01 80SX / 75,000 miles
Coupe: Feb 97 20V N/A / 135,000 miles
It doesn't go funny as such, but as soon as the temperature gets to 0 the handbrake seizes up. Tim is going to give it a good look over once the weather allows (no garage you see). Just a little fiat quirk, you get used to them!
I'm aware of the frozen handbrake issue but with the description of 'batterin' implied something else happened other than it froze.
Either that or I'm looking too deeply into it :)
when it snows i like to keep my car sideways at all times lol (constant yankin on it)
You are a clever chap then aren't you! No wonder you've broken it!
I used to do the same into parking spaces at my old house...it'd be rude not too :)
All it took was a tightening of the bolt directly underneath the handbrake handle.
I also never had a frozen handbrake in 7 years and I'm further north than all of you lol
mine never freezes :) then again i live 2 minutes away from the coast
She's a monster soon to be revealed :)
If they didnt want it stripping they shouldnt have used nuts and bolts :)
Anonymous it snows propa once every blue moon so when it does you gotta have some fun. Unless your a granny drivin 10 2 2 at the speed limit all the time if i wanted to do that i would have bought a volvo
I must be a granny then :)
Similar threads
