weird smell in my Bravo when I turn on the heat
A
Anonymous
Guest
Hy there,
I recently dicovered a problem with my Bravo: when I turn on the heat in the car I immediately notice a weird smell like moisture combined with wet socks...it's difficult to explain exactly..but anyway it's a bad smell.
I tried using two spray's of KlimaCleaner..but no result...
When I turn to Cold (air conditioner) the smell dissapears slowly...
Any idee what might be the problem??
I started thinking about removing the HeaterMatrix for a closer examination..but I think it will be very difficult to do that...
check ur radiator fluid
u might have a leak
She's a monster soon to be revealed :)
If they didnt want it stripping they shouldnt of give me nuts and bolts :)
Follow My Project
Updated: 12/11/2008
how difficult do you think it will be to remove the radiator from the dashboard???
It's necessary to remove the entire dashboard??
First did you change the pollen filter ?
Second, check the rubber outlet pipe on the wall of the car under the bonnet to the in car room, it may be blocked and not letting condensed water out.
Third, the heater matrix is easy to take out, just remove the glove box and some plastic trims that cower the matrix - or I may be wrong and its on the drivers side in UK. ;)
Members Site
Does it smell of amonia? Yes? Cat ****!!
The little b'stards get on your warm bonnet, snuggle down and can't be arsed to move when they need a ****.
Had it 3 or 4 times myself.
Mark.
Council estate lad.
And proud of it!
A battle of wits with the unarmed is no fun!
Member of the Guild of Experienced Motorists. Lapsed.
sabre23: I can't say that it smells like cat ****...it's a smell more like moisture..
I'm quite sure that is not from the cat's..
The pollen filter was just replaced vith a new one from fiat but the smell is still there.
I think that the only thing left is to remove the heatermatrix
by the way: where exactly is that rubber outlet pipe?? is it in the same space where is the motor from the wipers mechanism??
