![]() | #1 | ||
Guest | just did a fault diagnosis code test on the bravo and got... cylinder 4 issue..cant say exactly what it is as i left the readign at home but cylinder 4 is causing a problem now what do i do to rectify this..please help..
![]() | #2 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... what size engine do you have ??
![]() | #3 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... First tell us the exact fault code.
![]() | #4 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... will update you shortly i have a 1.2 2001
![]() | #5 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... I had this problem a few weeks ago, it was the coil pack,try the leads first as they are cheaper! if no different probably be the coil pack i bought one off ebay 1/2 the price than fiat and a 2yr guarantee!! good luck Jez.
![]() | #6 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... ok here is the official fault reading P0300 Ignition Failure (Generic) P0304 Ignition Failure Cylinder 4
![]() | #7 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... anyone?
![]() | #8 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... Could be plug lead or coil pack. Leads are cheaper so try them first. No harm in having new ones.
![]() | #9 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... hi so is this nothing to do with an injector?? i think it might possibly be the coil pack.. cant see a repair guide for fitting in a new coil pack..anyone know>
![]() | #10 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... Easy,held on with 4 torx/philips screws,and should be numbered 1234 so you put the leads in the correct places 5/10mins of a job!!!! ebay 40 odd quid guaranteed for 2 years.
![]() | #11 | ||
Guest | Re: just did a fault diagnosis code test on the bravo and got... An injector fault would be flagged as such in the error codes.
