T tina Guest Jul 11, 2008 #1 bravo 1997 new shocks, arms drive shafts replaced new clutch, balanced wheels still shakes at 40mph + any other ideas please
S Shaun Cook Guest Jul 11, 2008 #2 maybe u wheel is buckeled?? check ur brakes, make sure ur wheel nuts are tight. Its a 1.4 Chassis, 1.6 Engine and 2.0ltr Brakes and half a Marea Follow My Project Updated: 06/07/2008
OP OP T tina Guest Jul 11, 2008 #3 did hit curb quite hard other day run off rd have changed front wheels and there is still shaking not as bad as before but still there ???
S Shaun Cook Guest Jul 11, 2008 #4 u might have damage some internal parts. was is from that day it started shaking? Its a 1.4 Chassis, 1.6 Engine and 2.0ltr Brakes and half a Marea Follow My Project Updated: 06/07/2008
OP OP T tina Guest Jul 11, 2008 #5 yea pretty much someone has said it may be the ?shaft in gear box (sorry not mechanically minded) they also said that would prob be new gearbox !!!!
T Tommy L Guest Jul 11, 2008 #6 Did you hit a kerb after fitting all those new parts? You might have damaged your bottom arm/wishbone watever you wanna call it!
C Callum Guest Jul 11, 2008 #8 Read the other 'shaking' threads for ideas. If your running aftermarket wheels im going to put my money on incorrect sized spigot rings.
T Tommy L Guest Jul 11, 2008 #9 If it wasn't shaking before hitting the kurb, take the car back to the garage and tell them to sort it out!
