J James Guest Jan 3, 2008 #1 Hi folks, my dash, side and tail lights are out. fuses are all fine. any ideas.
E Ed Guest Jan 3, 2008 #2 check your earth connections ____________________________________________________________ 1.2 Bravo 80 SX
OP OP J James Guest Jan 3, 2008 #4 My stereo flickered off and on a few times the other day and i've had the problems with my, dash, side and tail lights since then. Bravo 1.4 SX
E Ed Guest Jan 3, 2008 #5 not actually sure where they are on the bravo - had this problem with a peugeot once and that was the fault. hope someone else can tell you where they are... ____________________________________________________________ 1.2 Bravo 80 SX
S Shaun Cook Guest Jan 3, 2008 #6 could be ur battery! happened to a friend at work, everything goes out and so that the battery can preserve the power to run the car CLOSED FOR CONSTRUCTION!!!! Ek weet nie waar ek gaan nie, maar ek weet waar ek was
