Old 03-12-2007   #1
Dave
Guest
Is it a write off.. / Mot failure..
the panel immediately behind the bumper.. the horizontal bar in front of the radiator..
this has a big dent in it.. its bent back slightly almost to touching the radiator. Is this a write off?
can this be replaced,
or is it a welded part of the chassis
Old 03-12-2007   #2
Anonymous
Guest
Re: Is it a write off.. / Mot failure..
if its your slam pannel you can replace it is it where you bonnet catches?
Old 03-12-2007   #3
Dave
Guest
its below where the bonnet catches.. its the horizontal bit that the bumper sits on.
the top of the bumper attatches to it by two bolts
Old 03-12-2007   #4
Anonymous
Guest
if its the bit im thinking off it un bolts, take out your head lights and have a look, while they are out replace with marea polys
Old 03-12-2007   #5
Ozric-Al
Guest
It's welded in unfortunately. It's not an MOT failure if it's bent but is if it's split.
Old 03-12-2007   #6
BenW
Guest
When I brought my bravo it had this same damage and was missing the bumper and lights and the bonet was also damaged and it was a write off.
However the panel is replaceable this is the one I think you need: Here
I think you just need to drill out the spot welds holding it in and then spot weld the new one into place.
Old 03-12-2007   #7
BenW
Guest
