Old 02-11-2007   #1
Buzz
Guest
RadWeld/Bars leaks opinions wanted
as title, i'm looking for opinions on the above products or similar products. I've got a tiny leak at the bottom of the rad on my 2002 skoda. I'm losing maybe 400ml of fluid every month(which is 4k miles) I say that just to give you perspective on how tiny a leak it is. I've not had the rad off or anything daft, but i suspect its one of the fins has been bumped an caused a tiny crack. maybe. lol.
So i was thinking about putting a bottle of leak sealer in, but as i've never ever had a leaky radiator that wasn't caused by an insecure hose, i have never used them, and dont know if they work.
Opinions/experiences please?
Buzz
The champion of the Bravo 1.4 & now ex owner of a Bravo 1.8
Old 02-11-2007   #2
Carroll
Guest
Re: RadWeld/Bars leaks opinions wanted
They work OK in that they will stop a small leak, but I would'nt use them in any car I cared about, because that stuff will also narrow passageways in other parts of the coolant system, which is not so clever.
Old 02-11-2007   #3
Anonymous
Guest
I used this on an old escort i had. was ok until i sold it 4 years later. Radweld.
Old 03-11-2007   #4
AlexW
Guest
Drain your system, dry round the leak, mix up some Araldite glue and paste it round the leak area. Leave it overnight and then re-fill/bleed system. Good as new. Used it often in the Army to seal leaks in header tanks etc.
Old 03-11-2007   #5
Buzz
Guest
i've got chemical metal, and i could patch it that way, by plastering all over that corner, but its so minute that i can actually see it, hence the presumption its inbetween fins where they meet the edge of the radiator (which would be hard to get glue into)
Ach, i'll give it a crack.. nobody's given me any reason not to try, lol.
Buzz
Old 03-11-2007   #6
axle
Guest
No need to patch it! chances are you would not find it and as you say, the cooling fins would be in the way. Radweld will do the job fine
Old 03-11-2007   #7
Buzz
Guest
uh-oh, your in trouble now if it dont work
Buzz
Old 03-11-2007   #8
axle
Guest
No worries mate. Just pour the radweld in and run the engine. as soon as the pressure is on, the hole will seal if it is as small as you say.
