my brava elx only seems to remote lock and alarm when i push the button on key but only de-arms the alarm and does not open the car i have to open then by key any idea's on how to fix it
hi,
I had a similar problem on a mondeo a few years back ( totally diffrent system i i know) but in the end i found the actual door lock was sticky. Ie it would close by the "fob" but was to tight to be undone by the solenoid in the door switch , a good squirt of wd40 problem sorted. Worth a look maybe Andy.
I will think on to see if i can think of anything else.
Is it possible that the relay has gone wonky and the part that operates the locking mechanism is knackered? Might also be a wiring connection come loose.
If you know someone with the same system, try swapping the relay. That should narrow down the possibilities.
