Drivers seat problem
T
Tom
Guest
The drivers seat on my '99 Brava has broken - I think it's one of the upright tubular sections.
Anybody out there know where I can get hold of a replacement please?
Failing that, is it easy to remove the cover so that I can get the broken part repaired?
Tom
you can get it welded. I take it that its snapped right at the join at the bottom corner?
failing that its about £60 for a new frame from fiat, and then you'd just have to transfer all the padding andcover over to the new one. Welding, unless you know someone who can weld, will prob cost £30ish
Buzz
The champion of the Bravo 1.4 & now ex owner of a Bravo 1.8
Thanks for that. It's actually broken at about shoulderblade height on the right hand side. I have a friendwho can weld it for me. Is it difficult to get the cover off?
Tom
there is a guide on the modding section of how to install heated seats elements, by Joske, the reason why i`m tellin you this is it would probably tell you how to remove your seats cover etc
http://www.fiatboo.co.uk/mod-a-bravo.htm#heat
hope this helps
BRAVO, why settle for anything less.
Thanks for that. I've printed out the instructions and I'll give it a go.
Tom
Similar threads
S
Replies
1
Views
586
Dark Lurker
D
W
Replies
Views
653
wakka
W
S
Replies
2
Views
482
S
T
Replies
1
Views
564
Joseph
J
