D
donny lad
Guest
listen guys ive justfound out that if you run the supercharger with less than 8psi you do not and i repeat you do not need to change the internals all you need is coupe turbo injectors custom brackets and pulleys and custom pipe workfor air intake, no need for cooler or ecu remap it should increase power by about 35% and the enginear reckons it would be a cost effective way of uprating power
