Old 05-02-2007   #1
carl
Guest
turbo or supercharger??
how differcult is it to turbo or s/charge the 2.0 20v. i dont fancy trying to find a 20vt in good nick and would like to try sumthin different.
i swear ive seen an Eaton surpercharger kit for the hgt but cant find any info anywhere?!?
any ideas?
Old 05-02-2007   #2
J
Guest
Re: turbo or supercharger??
Forget the N/A engine and get the 20V Turbo.
Old 05-02-2007   #3
Buzz
Guest
its never been a good idea to turbocharge an engine that was built as n/a
The whole thing isn't designed to take the additional pressure, and it just tends to go wrong, worst case scenario being the whole thing just smashes itself up inside.
As above, its best to replace the HGT with one thats had a coupe lump dropped into it already. Ribbz is selling a showcar standard bravo 20vt just now on pistonheads. Or you could get the conversion done yourself. if you can find a decent donor coupe
Buzz
The champion of the Bravo 1.4 & now ex owner of a Bravo 1.8
Member Page
Old 05-02-2007   #4
J
Guest
But carl already has a 20V Turbo Bravo.
The fact is N/A engines should stay N/A otherwise your trying to re-invent the wheel.
If your bored and want to do a project find a way of making our babies 4WD/RWD.
Old 05-02-2007   #5
carl
Guest
rwd sounds like fun, would prob need older fiat parts or alfa parts to do it tho. or even lancia!
Old 05-02-2007   #6
J
Guest
Well I've gotta do some more research but the new Alfa Brera 3.2 V6 Q4 JTS is 4WD and i'm hoping it's that box that i can get to fit, work and hold the torque.
Old 05-02-2007   #7
Paul R
Guest
just so you dont have to just accept that you can not do it i will elaberate slighty just for your infomation...
one of the main problems with turbocharging a na is that the na will run at say 170psi compression on each cylinder, wheras the coupe runs around 150psi, no i know those figures dont look a million miles away from each other but that is without the turbo spinning, once the turbo is spinning that psi mangnified greatly.... I dont have the exact figure to hand but say for arguements sake its x3 , that makes the coupe engines compression at 450psi and the na's with a turbo bolted to it 510psi, so youbasically blow the car apart
you can reduce your compression rating by using things like custom made head gaskets but its not worth considering when you could source an entire 20vt with everything there for less money.
Supercharging, it is feasible, although again too expensive, you can use an eaton superchange and use it where your air con compressor is (if you have one) but then you run into problems with the exhaust manifold... the list goes on...
Hope that helps abit more then just no
however i still agree with them, just get a coupe lump and drop it in or even just get a coupe, i did
2xHLX owner,3xHGT, (then the darkside) 1xCoupe20vt now the proud owner of a Black Coupe20vt LE!
Old 05-02-2007   #8
Chris
Guest
Its just not fair....how do people get the money to do these projects...that 4x4 conversion sounds awesome and i dream of puttin a 20vt in mine. but i cant get even close to raisin the funds...i work hard, dont pee me money up a wall, damm this world we live in. grrrrrrrr.
ok rant over. thank you.
it wud b nice to do something different as u suggest but just doing a 20v turbo to your own standard and putting your own stamp on your car moves you away from the crowd. fair play mate
Old 05-02-2007   #9
g5een
Guest
alot of people dont like to admit it, but mummy and daddy have alot to do with things. i wish my parents were minted lol
Old 05-02-2007   #10
J
Guest
If you were minted you wouldn't have brought a cheap crappy Fiat like the rest of us and be here now. You would be another tosser without brains and too much money and en up buying the new Audi TT
Old 05-02-2007   #11
g5een
Guest
i meant the younger generation. buy a car for 2.5k and manage to spend 5k on it +insurance when they only make 150 a week wages.
Old 05-02-2007   #12
J
Guest
Well thats mummy and daddy for you then
Old 05-02-2007   #13
Buzz
Guest
@J, Carl DOESN'T have a turbo lump. Thats the whole point of the thread, lol. Can he basically convert his 2.0 20v into a 2.0 20vt (t=turbo )
the answer, is not economically. Its faster and cheaper to swap engines.
Buzz
Member Page
Old 05-02-2007   #14
J
Guest
Old 06-02-2007   #15
Paul R
Guest
I wish i could have afforded to have done the said conversions, but with coupes getting down to 1.5k for dogs and 3k will see you a good one it just doesnt make sense (well not to me, i admire all that do it though, would have loved to have done it myself) If i wasnt technically minded, and didnt work at powerfiat i would not be able to run my coupe
As for the Q4 idea, one thing that might throw a spanner in ther works is that the v6 in the Q5 isnt an alfa unit, its from GM so gearboxes "might" be different, hope its not though as i would love to do it in the future
That said when i had my bravo coupes were worth quite alot more then they are now... you could get a rolled one for around 1k and recoupe about 400ish of that in selling parts...just ask johnybravo... and you could have a 20vt lump in your car for as little as 600 if you have the know how. (finding them is the hard bit)
Paul R
