Old 26-02-2007   #1
Kristian
Guest
Please help me identify my engine (1.2 16V)
Hi guys and gals,
I have a bravo/a engine from a breakers that I am fitting into a Seicento.
It's a 1.2 16V, I know that much, but as I don't know the donor car or its age, I haven't a clue what engine code it is for cam belts, HG sets etc.
It does have a cam sensor and it also has an alloy section between the sump and the block.
If anyone can tell me the engine code, or give me any more info I'd be most grateful
If you require any more details, just shout and I'll get it!
Cheers in advance
Kristian
Old 26-02-2007   #2
Sven
Guest
Re: Please help me identify my engine (1.2 16V)
Does it have a CAT just under the exhaust manifold or is it located under the car ???
Second, do you see any code on the head or on the block ???
Members Site - - - - - - - My Site
Old 26-02-2007   #3
Kristian
Guest
The block has the following marks:
0L2E
M657
A1
There may be more that I didn't spot though.
It came without manifolds so the CAT location is no help sadly. I have a punto mk1 inlet and tb, and a Super Sprint 1.2/1.4 Punto manifold for the exhaust.
Are there any other marks or hidden positions that aren't easy to spot?
Cheers for your help
Kristian
Old 26-02-2007   #4
Anonymous
Guest
Engine number is stamped on the cylinder casing ,just below the cylinder head
Old 26-02-2007   #5
Kristian
Guest
cylinder casing below the cylinder head?
You mean externally visible?
You have the cylinder head and the cylinder head extension. You mean it's actually stamped on one of these?
If so I need to get my magnifier out and start hunting Unless you mean its internal? If so, no worries, as I will pull the head anyway. Just hoping to know the right HG set before I do so
Cheers,
Kristian
Old 27-02-2007   #6
Anonymous
Guest
Well according to haynes, the engine # for the 1.2 is stamped on the front central of the engine block. I should think externally
Old 27-02-2007   #7
Kristian
Guest
Can't log back in? Very odd, even check my password
However .. success
I went on the hunt for the engine ID number, and found it along with the engine code.
Left of the engine from the front, beneath the exhaust manifold, on the iron block, just above the water pump outlet is a little ledge. On there is the ID number and the engine code.
Mine is rusty, and I just managed to make out the version 188A5000
The other number ends 38075* but the start is too corroded to read, wonder if that matters getting docks changed etc?
Cheers anyway guys, at least I now know what I have
Old 28-02-2007   #8
Anonymous
Guest
i shouldn't think it will matter, Why don't you try and clean it up with a wire brush on a dremel?
