B BRAVO_CT Guest Nov 9, 2006 #1 Hi guys, i was wondering has anyone removed the front grille, if so how do you do it? I've just had a great idea of dremeshing it, but its too cold to venture out and look under the bonnet! Thanks Bravo_CT
S Stu R Guest Nov 9, 2006 #2 Open bonnet. Look inside under where front grill sits and there are 3 small nuts (i think 8mm) to remove. Carefully pull off while making sure that the two clips at either side of the grille are clear from the bonnet. Members Page
OP OP B BRAVO_CT Guest Nov 9, 2006 #3 Thans for the quick reply! I'll give that a go over the weekend! BRAVO_CT
