FIAT Auto Specialist Team
Old 27-07-2006   #1
Anonymous
Guest
Wheel locking nut problem(BIG problem)
Why does everything go wrong at the same bloody time anyway ive got a really big problem ive lost the wheel locking nut socket and a need 2 fit my new discs and pads.Im not aware of any way of removing them without the socket.Will my local alloy wheel centre be able 2 remove this or a decent garage?
Old 27-07-2006   #2
Darren
Guest
Re: Wheel locking nut problem(BIG problem)
it shouldnt be a problem for most garages i was quoted 5 per nut to have removed last time or you can send away for a replacment key if possible
Old 27-07-2006   #3
Anonymous
Guest
Does anyone know if a gator grip would be anygood?
Old 27-07-2006   #4
Sven
Guest
It may work, but it depends on the bolt "look" - if you do try to use it - be cearful not to damage the bolt, or you may have to drill it out afterwards
And the above is if you mean this
Members Site - - - - - - - My Site
Old 27-07-2006   #5
Anonymous
Guest
yes sven thats the bit i mean.anyone else got any suggestions before i have ago n probs make things worse.
Old 27-07-2006   #6
Sven
Guest
well the safest way is to drill a hole, smaller then the bolt is in the middle of the bolt and using a thread cutter do a revers read.
Then screw in a normal bolt and using its head twist off the wheel bolt - if you get me
Old 27-07-2006   #7
Tom
Guest
Most wheel places will have a locking nut remover.
Old 28-07-2006   #8
Allan Wall
Guest
re
as above,
but, a low tech trick i have seen used is to buy two cheap sockets and just hammer them onto the lockers.
means you will never use them again but depends how urgent your need is.
Old 28-07-2006   #9
Anonymous
Guest
I worked at a garage for ten years and used to see this problem all the time. We had a socket the same as the one in the pic and it worked great aslong as the locking nuts/bolts wernt done up too tight. The other way is the method mentioned above, cheap sockets and hammer them on, but make sure you hammer them on well and get a nice tight fit as you may only get one chance before they round. All this is depending on the type of locking nut of course.
If you have the standard Fiat locking nuts you may be able to borrow a spare socket of a mate or someone else with a Fiat. When I was at Fiat we kept a selection of about 5 or 6 and that was enough to remove most of the nuts we encountered.
Hope this will help, Mark.
