im Axle Specialists
Old 28-02-2006   #1
ben
Guest
sunroof blind?
hi, im sort of new to this forum i have a question regarding the sunroof on my 1.4sx,
basically, (like everything else), it makes a really annoying rattling noise. i was wondering if it should have a sliding blind? or should there be a gap betweent the roof lining and the glass?
hope that makes sense,
thanx ben.
Old 28-02-2006   #2
steve
Guest
Re: sunroof blind?
Can't vouch for yours but my 1.2 has a sunroof blind.
I did hear on this forum once that the blinds have a habit of disappearing into the rear of the roof space when the sunroof slides back and not coming back out.
I suggest you get a torch and have a look in the gap.
Old 28-02-2006   #3
ben
Guest
Re: sunroof blind?
good thinking!
ill give that a go,
cheers, ben
Old 28-02-2006   #4
Anonymous
Guest
Re: sunroof blind?
if not i have a blind you can hav
Old 28-02-2006   #5
Ash
Guest
Re: sunroof blind?
they all have blinds it will be stuck down the back just force your hand down and pull it back
Im Driven to Earn, and I Earn to Drive......
Old 28-02-2006   #6
Tommy L
Guest
Re: sunroof blind?
The rattling could exist because the seal around the glass is worn and not a tight fit! My glass rattles a lot and when i close the driver or passenger door i can see the glass popping up!
You'll need a new seal around the glass! I've got a seal just haven't got round to fitting it yet as I'm too scared of the cold weather
Old 28-02-2006   #7
Lukas
Guest
Re: sunroof blind?
My blind was retrieved from in the roof void, but it had slipped all the way back to near the boot. A long thin pointy device was needed to reach it and tease it back.
Old 01-03-2006   #8
Dan E-S
Guest
Re: sunroof blind?
My Blind rattles alot but has not yet disappeared.
Old 01-03-2006   #9
Anonymous
Guest
Re: sunroof blind?
hi, thanks for the suggestions,
the rattling isnt the glass i dont think. it sees to be the metal strip that is in the gap between the headlining and the glass. will check the 'void' later on.
just have to sort out all the other rattles now
cheers
